Rivman1243
Все публикации пользователя Rivman1243
  1. Rivman1243
    A650E with a HF2A
    Does that have to correct output shaft for the HF2A? How did that person control the shifting?
  2. Rivman1243
    A650E with a HF2A
    The bellhousings have the same bolt pattern
  3. Rivman1243
    A650E with a HF2A
    Thank you for the reply. The A650e bellhousing and torque converter can be swapped for the A343F. I have a 1FZ-FE. The A650E has the 2nd gear one way clutch in the tailhousing. If I could find a bell for my 1FZ-FE that I bolted to the A750F or A760 I would try that.
  4. Rivman1243
    A650E with a HF2A
    What is ATRA
  5. Rivman1243
    A650E with a HF2A
    I'm doing my best to learn Russian and using a translation program. It's very slow going for me reading this forum. Not all the words translate correctly. If I have read that topic you posted correctly its possible to put all the clutches and gears of a 5 speed into the A343F case?
  6. Rivman1243
    A650E with a HF2A
    I've been searching the forum here looking to see if anyone has been able to install a A650E where a A343F was in a FZJ80. I'm interested in installing a 5 speed automatic transmission. Thank you
  7. Rivman1243
    Rivman1243
