Перейти к содержанию
Rivman1243
A650E with a HF2A
Рекомендуемые сообщения
  • Машина: 1997 Toyota LandCruiser
I've been searching the forum here looking to see if anyone has been able to install a A650E where a A343F was in a FZJ80. I'm interested in installing a 5 speed automatic transmission. Thank you
Поделиться на другие сайты
  • Машина: Невалятор, ТЛК 100 VX-R, горные лыжи и сноуборд
вот тут много информации по подобным работам
I'm doing my best to learn Russian and using a translation program. It's very slow going for me reading this forum. Not all the words translate correctly. If I have read that topic you posted correctly its possible to put all the clutches and gears of a 5 speed into the A343F case?
1 hour ago, vito7733 said:
Please refer from ATRA.
What is ATRA
20 часов назад, Rivman1243 сказал:
Нет .  Вы не правильно поняли .
Вам надо в A650E  заменить выходной вал  . Или и изготовить переходной вал между A650Е и HF2A
Изготовить переходник между коробкой передач и раздаточной коробкой примерно вот так
Купить или изготовить электронный блок управления для A650E.
55 minutes ago, AZIAT said:
No . You did not understand correctly.
You need to replace the output shaft in the A650E. Or make a transition between the A650E and HF2A
An adapter for Between the Make the the gearbox and transfer a case something like the this
Thank you for the reply. The A650e bellhousing and torque converter can be swapped for the A343F. I have a 1FZ-FE. The A650E has the 2nd gear one way clutch in the tailhousing. If I could find a bell for my 1FZ-FE that I bolted to the A750F or A760 I would try that. E3434EC8-6FF4-4278-947A-BFA3D8C26453.thumb.jpeg.888f72be6c1ebbfc1a309115ac25d630.jpeg
Изменено пользователем Rivman1243
Misspelled a few words
4 минуты назад, Rivman1243 сказал:
for the 1FZ-FE that bolted to the A750F or A760 I would try that.
Maybe 2uzfe and A750f and full electric for TLC100 ?
The bellhousings have the same bolt pattern
8 минут назад, Rivman1243 сказал:
Only output shaft .  but from 343 will not work
On 2/19/2019 at 12:00 PM, AZIAT said:
Not . You did not understand correctly.
You need to replace the output shaft in the A650E. Or make a transition shaft between the A650E and HF2A
Make an adapter between the gearbox and transfer case something like this
Buy or manufacture an electronic control unit for the A650E.
Does that have to correct output shaft for the HF2A? How did that person control the shifting?
Создать учетную запись
