    • Машина: LC200 V8
    @mishanja,
    If you could make log on 5th gear with this custom list would be perfect. Then you can put values in excel and you also know how perfect is your LC200. I can send you excel file. You also may need it in the future for reference :-)  better if you will not need it
    Engine Speed               - rpm
    MAF                        - g/s
    MAP                        - kPa absolute
    Intake Air                 - where MAF is, celsius -> kelvin
    Intake Air Temp (Turbo)    - after IC,     celsius -> kelvin
    Atmosphere Pressure        - kPa absolute
    Calculate Load             - to be sure we have 100%
    VN Turbo Command           - to see what ECU wants
    Actual EGR Valve Pos       - to be sure is closed
    Actual EGR Valve Pos #2    - to be sure is closed
    Target Booster Pressure    - to see what ECU wants
    Injection Volume           - possibly calculate Air/Fuel ratio
    Pilot 1 Injection Period
    Pilot 2 Injection Period
    Main Injection Period
    After Injection Period
    Pilot 1 Injection Timing
    Pilot 2 Injection Timing
    Main Injection Timing
    After Injection Timing
    • Машина: LC200 V8
    I added Air/Fuel ratio, it looks very good. For diesel it is in range of 18 to 70
